How do I add an Avatar to my Forum profile?
Large photo
When you are signed in and on the forum scroll to the top of the page.
Select/click on Edit Your Profile
You should now see a web form where there are 3 tabs along the top
[B][Profile Options] [Site Options] [Sign-in information][/B]
You want [B][Profile Options][/B] to be the one that is highlighted in bold test
First make sure the button "Enable Avatar (*) Yes ( ) No" is selected
Then check if no avatar picture exists on the page under Avatar ... you need to load one
Click Upload Avatar (Choose File) button
A MENU WILL POP UP FOR YOU TO SELECT YOUR IMAGE FILE FROM YOUR COMPUTER
Once you select a file and return to the Beoworld webpage you need to then click the (Update) button
A page refresh happens but your Avatar picture remains unchanged
Then scroll to the bottom of the webpage and click the (Save) button
Another page refresh happens and then the Avatar picture is replaced
And voila you are there !!
Reference: 99
Created: 18th July 2010
Modified: 18th July 2010
Thanks to BeoWorld Member 'Elephant' for this guide!
My BeoWorld
0 items in your basket
Need a cable? Just ask Steve at Sounds Heavenly
Want to sell your B&O products
