Where is the DVI Socket on my BeoCenter 6 - 26 ?
As you look at the rear of the television, ignoring the main cable panel in the centre, you will see approximately 6 inches from the bottom of the TV a series of ventilation slots. In the middle of the left hand side of ventilation slots is a concealed panel. Simply remove this panel and you will find the DVI socket.
Reference: 95
Created: 3rd December 2008
Modified: 3rd December 2008
My BeoWorld
0 items in your basket
Need a cable? Just ask Steve at Sounds Heavenly
Want to sell your B&O products
