My BeoCenter 9500 displays "CODE"
Large photo
This usually happens if you have replaced the S/W or the lithium battery has been replaced or needs replacing.
Fix the battery or RAM and then:
Using a Beolink 1000 press:1271
After 3 seconds, disconnect the 9500 from the mains and then reconnect. - Done!
Reference: 76
Created: 26th March 2007
Modified: 26th March 2007
My BeoWorld
0 items in your basket
Need a cable? Just ask Steve at Sounds Heavenly
Want to sell your B&O products
