My BeoCenter 2 has frozen - Help!
Large photo
Check the cable between the Master panel and the socket unit for a start. In some cases it may not have been pushed in firmly enough, thus not enabling a clean connection. Also check that the "blade" end of the cable isnt the wrong way round! - this can cause damage.
If the cable is in place correctly - switch the unit off at the mains and unplug and then plug in the cable at both ends. Do be careful, and remember - if the plug is put in upside down, you will break something!!
If problems persist, you will need to call your nearest Bang & Olufsen dealer or Service Centre.
Reference: 53
Created: 4th March 2007
Modified: 6th March 2007
My BeoWorld
0 items in your basket
Need a cable? Just ask Steve at Sounds Heavenly
Want to sell your B&O products
