Can I Wallmount my Beocenter 9000/9500/9300?
Large photo
If you mean vertically, the answer is definitey no.
The CD player is not designed for this. There was however a bespoke wall mount which allowed the Beocenter to be fixed at a 45 degree angle though this is no longer available. Mounting it horizontally on a shelf is obviously the only remaining option if you require it to be mounted higher than floor or table level.
Reference: 43
Created: 1st March 2007
Modified: 7th March 2007
My BeoWorld
0 items in your basket
Need a cable? Just ask Steve at Sounds Heavenly
Want to sell your B&O products
