Which Record Player will work with my system?
Large photo
If your system dates from before the Beocenter 9500, it is likely it has a special input designed to take a record player. If so, the world of Beograms is open to you! All of the Beomasters utilising datalink will work with all the decks except:
Beomaster 4500
Beomaster 3500
Beomaster 6500
Beomaster 7000
These Beomasters require a deck with a built in pre-amplifier known as a RIAA. The decks so fitted are not suitable for the other Beomasters. They are:
Beogram 3500
Beogram 4500
Beogram 6500
Beogram 7000
These decks have the additional advantage of being able to work with the Beocenters made after the Beocenter 9500 and Beosound music players. For instance:
Beocenter 9300
Beocenter 2500
Beocenter 2300
BeoSound Ouverture
BeoSound 3000
Beosound 3200
BeoSound 9000
The Beocenter 2 will also require one of these decks but does not have a DIN socket for an AUX input.
There are a couple of oddities in the range. The Beogram 6000 quad is fitted with a CD4 demodulator which produces 4 output channels at line level and can be used as a stereo deck with the above systems as well - and very stylish it is too!
Reference: 42
Created: 1st March 2007
Modified: 30th September 2007
My BeoWorld
0 items in your basket
Need a cable? Just ask Steve at Sounds Heavenly
Want to sell your B&O products
