My old speakers have 'Foam Rot' - help!
Large photo
From where might I obtain a new driver for my Beovox loudspeaker?
The material which makes up any loudspeaker gradually deteriorates over time. Occasionally 'foam rot' may set in. You'll know this as the driver within the loudspeaker cabinet has dust around it and it becomes loosened. The sound quality may well be impaired too. Sometimes - as in the case of the newer CX50 and CX100 passive loudspeakers - you can obtain replacement parts from your B&O dealer.
Another UK-based company - Recone - manufactures components for a broad range of Bang & Olufsen loudspeakers, and many of our members speakers have been saved by them!.
Recone Lab
Victoria House
Victoria Street
Lockwood
Huddersfield
West Yorkshire
HD1 3RG United Kingdom
Telephone: 01484 549899
Fax: 01484 533038
Email: reconelab@loudspeakersonline.com
Reference: 21
Created: 15th January 2007
Modified: 12th August 2007
Related Discussion Forum Threads
My BeoWorld
0 items in your basket
Need a cable? Just ask Steve at Sounds Heavenly
Want to sell your B&O products
