Which Beogram will work with my System?
Large photo
The important thing to remember here is that the output from a magnetic record player cartridge is at a lower level than that of other sources and is also skewed in such a way that it would sound very tinny if played directly.
Therefore a small pre-amplifier is required which will amplify and equalise the signal. This is known as an RIAA.
The RIAA is only required in one location. Modern B&O systems do not have one in the main system so one will be required in the Beogram or fitted externally. The Beogram 3500, 4500, 6500 and 7000 all have RIAAs fitted as standard.
Reference: 18
Created: 15th January 2007
Modified: 26th March 2007
My BeoWorld
0 items in your basket
Need a cable? Just ask Steve at Sounds Heavenly
Want to sell your B&O products
