Which Beogram turntables can be wall-mounted?
Bang and Olufsen produced an excellent wall bracket for their Beogram record players in the 1980's that seemed to disappear under the turntable, leaving the Beogram seemingly suspended in mid air. Sadly, these are no longer in production and they are now very rare, so STB Brackets have improved on this design and developed an updated version of the B&O wall shelf.
As with the original B&O brackets, these new brackets will fit many of the B&O Beogram range, including the models listed below:-
Beogram 1000, 1500, 3000, 3300, 3500, 4500, 5005, 5500, 6500, 7000, 8500, 9000, 9500, TX, TX2, RX, RX2
The dimensions of both the original and the re-manufactured brackets are almost identical, at around 33cm wide x 30cm deep x 7cm high. Basically, if the depth from the back edge of your B&O turntable to the front feet underneath is 30cm or less, then these shelves will fit your Beogram.
Reference: 105
Created: 29th May 2012
Modified: 29th May 2012
My BeoWorld
0 items in your basket
Need a cable? Just ask Steve at Sounds Heavenly
Want to sell your B&O products
