How do I know if my remote control is working?
Just find a digital camera (or camera phone) and switch it on so that the screen shows a picture (don't press the shutter button). Hold the front end of the remote control up to the camera lens so that you can see the small black "window" on the screen. If the remote is working properly, you should see fast, bright flashes of white light on the camera screen when you press a button on the remote. If the flashes are dim, the batteries probably need replacing. If nothing shows, your remote control is likely to need repair or replacement.
Reference: 102
Created: 29th May 2012
Modified: 29th May 2012
My BeoWorld
0 items in your basket
Need a cable? Just ask Steve at Sounds Heavenly
Want to sell your B&O products
