How do I change the region code on the DVD1?
NOTE: This method does not make the DVD1 Region-FREE. There is a limit of FOUR changes to the product over its lifetime (without professional servicing.) USE THIS INFORMATION AT YOUR OWN RISK.
Remove any CD or DVD and disconnect the power.
Press and hold << and >> on the front panel (not the remote) while reconnecting the power plug.
The current setting shows on the display.
Use << or >> on the front panel (not the remote) to change Region number.
Press PLAY to store. Wait 15 seconds until TV screen shows blue.
See http://en.wikipedia.org/wiki/Dvd_regions for information on specific regions.
Reference: 78
Created: 30th March 2007
Modified: 30th March 2007
Thanks to matheyl.
Did this article help you?
We hope that our frequently asked questions are helpful, however your feedback is essential for us to improve our service. Please let us know using our feedback form if we can make any improvements or if you have any further questions. We read feedback carefully, but please note that we cannot respond to the comments you submit. Thank you for your feedback!
If you have an unresolved technical issue, you can probably find some help or additional tips in our Forum.
