Why DAB?
Large photo
DAB - Digital Audio Broadcasting
Digital radio loud & clear
What is DAB Digital Radio?
DAB digital radio is not satellite radio; neither is it Internet radio. DAB digital radio is a new way of broadcasting radio via a network of terrestrial transmitters. It provides listeners with more choice, better sound quality and more information. DAB digital radio is like analogue radio, only much better. In the UK, the BBC was the pioneer of digital radio beginning transmission in September 1995. Digital One, the national commercial radio multiplex operator began broadcasting in November 1999.
DAB is similar to analogue radio but provides high quality listening, many new stations and no frequencies, making it easier to tune to stations. There's no interference and no retuning in the car. In addition there are new features such as text, data and even pictures.
Tomorrow’s DAB digital radios will do more. 'Rewind radio', record programmes in real time or set a timer, download audio and data - the technology for all these functions already exits. You can use an EPG (electronic programme guide) to organise your listening preferences, save a programme for later, or dig down for more information on news, finance and sports stories. Each multiplex operator can allocate 20% of their capacity for data (see below).
If you live in a poor signal area where the FM signal is barely audible, then DAB may offer you better reception. About 80% of the UK population (2003 figures) can already receive digital radio.
How does digital radio work?
Digital radio works by combining two digital technologies to produce an efficient and reliable radio broadcast system:
An audio compression system, called MPEG, reduces the vast amount of digital information required to be broadcast. It does this by discarding sounds that will not be perceived by the listener - for example, very quiet sounds that are masked by other, louder sounds - and hence not required to be broadcast, and efficiently packages together the remaining information
COFDM technology, (Coded Orthogonal Frequency Division Multiplex) ensures that signals are received reliably and robustly, even in environments normally prone to interference. Using a precise mathematical relationship, the digital data signal is split across 1 536 different carrier frequencies, and also across time. This process ensures that even if some of the carrier frequencies are affected by interference, or the signal disturbed for a short period of time, the receiver is still able to recover the original sound.
The interference which disturbs FM reception, caused by radio signals 'bouncing' off buildings and hills (multi-path) is eliminated by COFDM technology. It also means that the same frequency can be used across the entire country, so no re-tuning of sets is necessary when travelling, or taking a portable receiver to a different area. Instead of having a different frequency for each radio station, digital radio combines several services together in what is called a multiplex.
The multiplex is able to carry stereo and mono radio channels as well as services such as text and data. The UK has been allocated seven multiplexes by the Radio Authority - in the spectrum 217.5 - 230.0 MHz. It is possible to carry more services on this one frequency allowing the spectrum to be used more efficiently.
The multiplex has a gross capacity of 2,300,000 bits which are used for carrying audio, data and an in-built protection system against transmission errors. Of these about half the bits are used for the audio and data services. Throughout the day, the data capacity allocated to each service can be varied by the broadcaster.
Each multiplex can carry a mixture of stereo and mono audio services and data services too; the number of each dependent on the quality required. A multiplex is a technical term used for "a number of stations sharing just one frequency to transmit its services". It is a digital transmitter located within a region broadcasting stations operated by a company or group (e.g. BBC, Digital One, Switch Digital etc).
A multiplex can broadcast data as well as sound. An example of a receiver is a product available for desktop PC's - the Wavefinder from Psion. There are two channels available on DAB currently broadcasting data. These are Digizone and BBC Vision Radio. Digizone is an interactive service where users can play games and interact with radio stations broadcasting on the Digital One commercial multiplex. BBC Vision Radio is a data station broadcasting world news, weather updates, sport and business news, travel updates and also programme details of all BBC Radio stations. These services can only be received via a Wavefinder or Digital Radio PC card.
So what are DAB's benefits?
Quite simply... more choice! Listeners in most major towns and cities in the UK can receive between 30 and 50 radio stations with digital radio, in many cases that's more than double what's available on analogue. And it's not just more of the same - the content within that choice of stations is unique and exciting, delivering station formats that just don't exist on analogue. The FM spectrum is so clogged right now that there's no room for new stations that would expand listeners' choice with, for example, soul music, or country music, or big band swing, or any of the other 100+ brands that are available uniquely to DAB.
More Information! Digital radio receivers have a screen on which stations can transmit information via Dynamic Label Segments (DLS). Some stations already transmit the latest news, travel, and weather, what's on now and next, Web site addresses and phone numbers. Tomorrow's radios will offer much more sophisticated data. The potential for advertisers to use the DLS facility on DAB for targeted advertising is an exciting prospect, and in the future, advertisers can use DAB to deliver Internet-type commercials.
Because digital radio uses the spectrum more efficiently than analogue, it is possible to broadcast more channels using the same frequency, making room for broadcasters to expand their station portfolios.
It also offers less noise. DAB digital radio delivers improved sound quality. The technology allows the receiver to lock on to the strongest signal it can find and ignore everything else. This eliminates the hiss, crackle and fade so familiar on analogue radio.
With DAB digital radio there are no frequencies to remember and sets are tuned by station name. National stations stay put, so there's no retuning on the move.
A Bang and Olufsen DAB receiver was commissioned by and developed for Danish Radio. It was a special series, of which only 500 were made. This Bang & Olufsen DAB receiver (based on a BeoSound 3000) is not for sale. This prototype was displayed at the IFA 97 exhibition in Berlin.
'Clear signals for digital radio' by Mark Ward - BBC News Online technology correspondent
The success of digital radio has been predicted at regular intervals over the past three years by both makers of radios and backers of the technology. But 2003 could be the year that the technology really takes off. So says Annika Nyberg, head of the international forum set up to drive development of the technology and tell broadcasters and listeners what it can do for them.
"The networks are there, the basic legislation is there, the frequencies and multiplexes are there and the services are there," she said.
"We are getting a wide range of receivers and prices are coming down to the point where cost is not a problem," she told BBC News Online. Digital radio is certainly due some significant success.
Good signs
The BBC turned on the UK's first digital services eight years ago and four years ago Britain's first new commercial digital radio stations took to the airwaves. In addition, 2002 saw the arrival of the first sub-£100 pound digital radios. This is a far cry from only two years ago when prices were high and interest and awareness among the general public was low. At that time there were only 24 digital radio stations in the UK. Now there are more than 100 and 80% of the country can receive digital radio stations.
Christmas is a popular time for buying radios
The omens are good that 2003 will be a watershed for digital radio. Audience figures released in mid-May show that the numbers of people tuning in are growing and that many niche stations are starting to win significant numbers of listeners. Ms Nyberg is also expecting sales of digital radios to be big at Christmas, the time of year when 80% of radios are bought.
"There is huge demand building up towards Christmas," says Ms Nyberg. "We really need those production lines to be working." Demand for digital radio sets has risen steadily over the last 12 months. So much so that makers of sub-£100 digital radios, such as Imagination Technologies and Roberts Radio, have been unable to keep up with demand. This has not been helped by the fact that some big manufacturers have yet to start making or selling digital radio sets.
Ms Nyberg says that Dutch electronics giant Philips is not selling a radio set of its own, even though it owns the pool of patents that define the core digital radio technology.
She feels Philips, Sony and other electronics firms are missing a huge opportunity because people who convert to digital radio rapidly become firm fans.
In 1997 Bang & Olufsen signed a contract with Denmark Radio to deliver 500 stationary DAB test receivers. The receivers were delivered in the first half of the year. The receiver was based on a modified Beocenter 2300 and a DAB module from Bosch-Blaupunkt, with whom B&O signed a cooperation agreement on DAB technology. The receiver was optimised for tests to give maximum results. New features could be downloaded easily and a very advanced remote control and display unit was part of the solution.
Popularity contest
What has been surprising, says Ms Nyberg, is the speed with which people who own one digital radio buy another. "They buy the first digital radio because of the new services," she says, "but they buy the second because the sound quality is so good." Despite the growing success of digital radio, what has yet to be felt is the full impact of the technology on the existing broadcasters.
Radios have changed with the times
The efficiencies of digital radio means it becomes possible to divide audiences very finely and target shows and services more accurately, says Ms Nyberg. Commercial broadcasters are only just beginning to work out how they can use digital radio to boost income. Eventually conditional access models may develop which give listeners the ability to download songs or interact for a small fee.
"You already pay for radio indirectly through licence fees or advertising but you do not perceive it as paying," says Ms Nyberg. Even mobile phone firms are considering using digital radio as a means to get music, movies and other services to so-called third-generation handsets.
"Digital radio can deliver the same sort of content they thought they could deliver through the 3G network but it does it much, much cheaper," says Ms Nyberg.
The message about digital radio seems to be coming through loud and clear.
Created: 10th January 2007
Modified: 2nd April 2007
Did you find this article interesting?
We hope that our articles are interesting, however your feedback is essential for us to improve our service. Please let us know using our feedback form if we can make any improvements or if you have any further questions.
My BeoWorld
0 items in your basket
Visit LifeStyle AV for pre-owned Bang & Olufsen
Visit STB Brackets for Bang & Olufsen brackets
Hygge Living - Bang & Olufsen Installation Specialists
